A
All U Get
removehtml]Has anyone ever used two props on a single shaft? A while ago I had read about a shaft extension that would allow a larger prop, but never using two. Without technical examination of horsepower, torque, ect. has there been any research? I've seen some power boats with a screw look rather than the typical fan blades. A second question is what determines the distance between the tip of the blade and the bottom of the hull? There is probably some hard and fast rule for optimum propulsion size, any suggestions?Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
