my reasons for a 3 blade
I put a 3 blade on my 81' H30 because the boat had a hard time fighting the tide in certain parts of the harbor. We would go out and the wind would die, and it would take a long time to motor through certain areas because of the tide surge. The 3 blade does provide a lot more thrust and makes the boat more responsive under power (stop means stop now, go means go now, etc). Prop walk is also less, simply because the boat gains speed in reverse faster, so the helm becomes usable sooner than than it did with the 2 blade. It does have vibration at some RPM's, but I can work around that. I have lost boat speed because of it, but not a lot. If I used the boat more I would probably invest in a folding prop, but for me the simplicity of the fixed 3 blade ws the best way to go. When I switched, I dropped 1 inch off both diameter and pitch.
