F
Frank Walkker
I am considering a new 3 blade prop for my 30' Hunter with 2GM20 engine. Everybody from A to Z says to select a prop that will let the engine reach 3400 RPM under calm conditions. I cruise my boat at 2400 RPM and on rare instances 2600 RPM. Because of the difference in the engine power curve and the propellor power curve I am extracting approximately 6 hp of the avaliable 12 at 2400 RPM. As long as I realize my limitations, it would seem to be to my(and the engines') advantage to overprop a bit to more closely load the engine at these speeds. Would somebody kindly explain the error in my thinking.
