Proper Prop?
Milt Songy
My '99 320 is a wonderful boat, but I'm wondering if it came with the right prop. I have so little power in reverse it prohibits bow-in parking. Can't stop! Great in forward, but the three fixed blades go to sleep when trying to back down. My dealer offers no clues. Anyone have any suggestions?
Stan Rogacevicz
How Bad is Bad?
I moved up from a c28 to my 99 c320 and I was surprized at how the weight difference makes me get real serious (maybe 2000+ rpm) with the throttle in reverse when I come in a little too fast. It's a Heavy boat, it wants to just keep on going. I certainly don't consider it a problem though so it's hard to say from here whether you really have a problem or not. What did you move up from? If it was a lightweight you are in a whole different world now. Stan "Christy Leigh" c320 #656
Milt Songy
How heavy?
I moved up to the 320 from a Pearson 30, with a two bladed prop. Thanks for your reply.
Stan Rogacevicz
Do some speed tests.
Milt, First to your How Heavy question. Except for the big buck Blue Water Cruisers Catalinas are about the heaviest producton boats anywhere near thier price range. The Pearson 30 you had before may have only weighed approx. the same as the c28mkII wing keel I traded for my c320 wing keel. For your original question I would do a speed test to see if you can get 7kts. in forward. If you can, I would still verify that speed by GPS and or a timed bouy to bouy run in flat water at slack tide. My c320 was delivered with the knot meter about 1.5 kt. low. If you are getting a true 7-7.2kts. through the water then I would say your prop is fine. Don't forget that sailboats are designed to go forward - including the efficiency of the prop. All props except for the AutoProp are less efficient in reverse. The Max and others are supposed to be beter than fixed in reverse. That is a big selling point of the AutoProp - it's blades pivot around to give you the exact same prop in reverse. I crawl up to the area of my slip hit neutral and drift through the 2 back to back 90 degree turns I have to make before shifting back to forward at an idle to enter my slip. The Inertia of about 13,000lbs cruising, not dry weight, is a force to be reckoned with. Stan "Christy Leigh" c320 #656
K
Kirk McCullough
Mine works fine
I have hull #124 with the 3 blade fixed prop. It works very well in reverse. In my slip I normally dock bow in and when I slip the engine into reverse and stab the throttle, the boat will stop "on a dime". Have you checked your gearbox to see if it is properly engaging in reverse. I have had some gearbox problems. Check the fluid level, if its low, the gears may not engage properly. Have you considered signing on to the C320 users email list. go to the C320 web site and sign up. C320 owners are the greatest in sharing information like this.
