Propellor safety pin?
183
Catalina 1990 Catalina 30 Mark II Harbor Island Yacht Club, Old Hickory Lake, Nashville, TN
I had a diver clean my boat bottom yesterday, and he told w that he couldn't see a safety pin on the prop.
Question: does the C30 have a hole in the shaft for a safety pin, or do C30s use a 2nd nut to lock the prop in place?
Thanks,
Bob
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Typically you would have a jam nut, a king nut and a cotter pin. Less frequently you would have a castle nut and a cotter pin. In any event, without the cotter pin your prop is not secure.
Feb 5, 2012
183
Thanks; the diver couldn't see a hole so we're thinking there's a pin in there but it may be broken off...
Feb 26, 2011
1,440
There are occasions where the end of the shaft may have been cut off (as in a certain percentage of Max Prop installations) so it is possible there is no hole, although that's probably unlikely.
Feb 5, 2012
183
I talked to the previous owner; he doesn't remember if it had a cotter pin or not.,I bet it's just rusted off; I'm going to get the diver to take a second look...
Feb 26, 2011
1,440
Have him go in with a selection of pins to choose from, a hammer and something to drive the old pin out of the hole.
Bob S
Sep 27, 2007
1,813
Beneteau 393 New Bedford, MA
Mine has a slotted nut with a cotter pin. I installed a new prop and used a stainless steel cotter pin with a bronze shaft and prop. I re-pitched the prop after 2 seasons and the cotter pin broke when I tried bending it back. I am using a brass cotter pin this season. The nut rotation could be hiding the hole.
courtesy of McMaster Carr
