Yes it is definitely good idea, but it will have increased cost. Having a fixed three bladed prop is like dragging a bucket of the same diameter though the water when the engine isnt 'on'. Not only will the boat be slower, but it wont be able to 'point' as well as a boat with a folding/feathering prop.
If you can adequately FIT a 3 blade 'folder' (you have to watch out that 'swing of the blades' doesnt come in contact with the rudder, etc.) you will most definitely have less drag; hence, increased sailing performance/speed, etc. A more common alternative, albiet more expensive, is a three blade 'feathering prop' - Max. prop, Auto-prop etc. more thrust, a a wee little bit more drag than a 'folding prop', if you cant dimensionally FIT a 'folder' ... most 'folding props' are 2 blades. The newer feathering props can easily have their pitch changed --- without having to haul the boat out of the water to do so. Folding props generally are more 'robust' than feathering props due to their more simplistic design. Why not a TWO bladed folding prop - martec, (volvo?), etc.?
Folder or Feathering --- definitely go for it; and, stop dragging that 'bucket' around.
For a H49, I would guestimate a ~1 to 1.5+ knot speed increase near the 'top end', faster acceleration out of a tack, better lightwind performance, less vulnerable to 'crab/lobster floats/warps'. etc. etc. etc. etc.
