Propeller zinc selection
FredW
Sep 8, 2010
7
Beneteau Oceanis 34 Severna Park
short of pulling the zinc, any way to determine what size fits a 2013 Oceania 34?
FredW
Sep 8, 2010
7
Thx, as I have to dive to replace it, I will get the 25mm and get a size large and smaller and have them available if needed.
RoyS
Jun 3, 2012
1,742
Isn't the shaft visible inside the boat behind the transmission?
1,440
Achilles SD-130 Alameda, CA
Your Beneteau 34 has a 25mm shaft. Don't bother trying to source the next size down (20mm) as you will not likely find one and I guarantee your boat doesn't use it anyway. If it makes you feel better to also buy next size up (30mm), knock yourself out but you'll just end up returning it.
We replaced the prop on our Oceanis 37 with a Flex-o-Fold with 25mm hub. I'd be surprised if the 34 was different.
fmwiii
Jun 24, 2013
1
All, Thanks for the feedback! I have measured the shaft at the back the transmission. I have also registered with Beneteau in anticipation of other questions. I will be going over the side shortly!
