I'm brand spanking new at sailing and boating so pardon the novice questions and wrong terms. I recently took my S2 27 (8.1) out for a sail, at some point we started taking on water (ankle high), needless to say it was quite the ordeal. Anyhow all turned out ok, made it back to the marina under sail (no propulsion) and figured out that the prop shaft had come completely out. The two locking bolts with tie wire and counter nuts were still installed on the collar. I was told later that this hasn't been serviced since new (1985 model). What would cause the shaft to fall out like this? Is it something I did?
The boat is still in the water but now noticed that the stuffing box is dripping quite a bit at stand still. From what I've read it should drip two drops per min while spinning. I will try and tighten it first but if not successful can I replace the packing while it is in the water?
Thank you all in advance for your suggestions and advice!
