Propeller shaft drip
41
in between boats for now Plattsburgh Boat Basin, Plattsburgh, NY
Help please. There seems to be a drip every 2 seconds coming from the joint where the propeller shaft exits the hull. Can this be repaired easily or is this a job for a marine mechanic and is it costly? Can I run the propeller or is it too risky? Thanks ~~~_/)~~~
Bob
Stuffing Box Leak Rate
Hi Michel, The shaft passes through a stuffing box. The stuffung box usually has a couple of large nuts - one is the packing nut the other a lock nut. Loosen the lock nut and then tighten the packing nut about 1/8 to 1/4 of a turn. Tighten until the drip rate is 1 drop every 20 seconds to one / minute, then tighten the lock nut against the packing nut. A drop every 2 seconds is not excessive. You will need a little leak - the leaking water lubricates the seal. Have seen the leak rate published as 0 drops without shaft rotation and 1 drop per 10 seconds with shaft rotating. Again it is not critical unless the packing nut is too tight = no leakage = failed seal and shaft damage. Hope this helps. Bob
Apr 30, 2008
41
Thanks for your replies
Thanks for your replies Bob, Larry. This is soo helpful. Larry, I'm sitting here in my boat as I type this message drinking a cup of Java. Sailed yesterday, was great (little wind but hey, I'm out there ) Will sail a little this morning before I must return home. Be back on the weekend. Oh yeah, the drip is fixed. Rgds Michel
