Propane tank solenoid threads
Oct 14, 2021
23
Hunter 42 Passage Marathon
I have a ‘96 Hunter 42 Passage with original solenoid and regulator on the external propane tank. The hose to the oven/stove was replaced prior to our purchase! I have been unsuccessful in identifying the threads. That’s the one component in the boat that has no documentation. Help is appreciated!!
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
I just changed ours out last year and this was the exact replacement. Not certain what thread size you are referring too here but this gives a lot of the technical information. Good luck!
Feb 10, 2004
4,185
Hunter 40.5 Warwick, RI
If it is the hose that connects to the tank, it is either a left-hand male thread that screws into the tank valve fitting or it's a right-hand female thread that screws onto the tank. If it is the connection to the stove itself, I have no idea. The manual for my Seaward Stove, which may not be teh same as yours, only shows a "gas fitting" with no size indicated.
Likes: Parsons
Oct 14, 2021
23
Thanks. Think I will head in tomorrow with my regulator/gauge and the hose to my old solenoid.
Oct 14, 2021
23
I have the same document! I bought a Trident solenoid and none of the hose connections fit. They are off by a little. I will pack it up and head into one of the marine stores to see what they can figure out!!
