Propane Switch Indicator Light
Jun 15, 2012
719
BAVARIA C57 Greenport, NY
My propane on-off switch red indicator light has burnt out. Has anybody had to change? I do not see any screws on the face plate. How does it remove?
May 24, 2004
7,237
CC 30 South Florida
I assume you are referring to the remote electrical switch that controls the solenoid valve. I would take a small flat screwdriver and very lightly pry around the face or body to probe and see where the attachment points are. Some faces or units just snap into place. They come in different configurations from different manufacturers. Pry lightly so as not to break plastic or mar the finish.
Mar 20, 2012
3,983
the majority of them I've dealt with of them are just pressed in to the aluminum plate.... you can either pry it out like has been suggested, or remove the plate from the wall and push it out....
some of the older plates had plastic grommets/bezels that held the light into the plate, and if they break you probably wont be able to find a replacement....
but there are options... some electronic stores, where you find small LED replacement lights, they usually carry the special rubber grommets to hold the lights in, but if not, a properly sized grommet from the wiring section of any hardware store will work.
in either case you may have to drill out the hole in the plate a little to get the new rubber grommet to fit, but it will look nice and work great.
Aug 17, 2010
208
Hunter 410 Dover NH
I don't remember how the faceplace came off, but I did replace the led several years ago. We got a new led either online or from radio shack. Soldered into the same spot as the old one.
