Sailboat is 2000 Beneteau Oceanis 36 CC.
Solenoid cuts gas off after few minutes, barely enough time to boil kettle of water. Consensus is that solenoid needs replacing. Manufacturer of solenoid suggests replacement with more robust solenoid valve & coil. Availability of replacement is an issue. May have to locate item from other supplier/manufacturer.
Need to know orifice size on the valve and pressure at the inlet port. This information not forthcoming from Beneteau as it refers owners to its dealers for such technical information/assistance.
Any directives, instructions, details, specifications, part numbers, part sources that will assist this resolution much appreciated.
Photo of current Parker Hannifin coil attached.
