I am looking to clean up the rat's nest otherwise known as my breaker panel. In looking to accommodate the Trident Gas Control Panel along with an expanded set of breakers to eliminate all the doubling up that I have, I notice that the gas control is simply a 1A breaker with an indicator light taking up a fair amount of space on its own panel. The new panels I will be installing have LED indicator lamps. I cannot see any reason to not simply use a 1A breaker, properly marked, in the panel. Am I missing something here? I notice that Blue Sea does not print a "Propane" label for use on their panels.
