detectors a good tool, if used right
I've used propane/butane stoves for cooking for the last 30 years with no incidents. Before then, I'd get a flare up about once per year with either gasoline or alcohol.To be safe, All fuel of any kind is stored on deck at the rear of the boat.When used inside for cooking or heating, the connection is checked for leaks while in use, and as soon as cooking or heating is done, the fuel container is removed and stored outside with the fuel supply.Not only is a CO2 and propane detector and good idea for travel trailers and any size boat, but they must be installed correctly. Both CO and CO2 and propane are heavier than air so the detectors must be mounted low, near the floor or deck so maximum warning rtime is given sleeping occupants. Battery powered ones should have fresh batteries installed at least twice a year. If wired to the boat's battery system, be sure to have the battery system fully charged before cruising and charged again during the cruise because the detectors will give alarms for low voltage. In addition to the fuel fumes, many people die on boats each year from CO poisoning because of using open flame devices below decks without adequate fresh ventilation. Some people die without being aware that anything is wrong until their brain fades away and leaves them helpless. Be careful out there and enjoy sailing until you are a very old salt like me....
