Thoughts on Showers
During twenty years in the Army, and deployments all over the world, I always carried a solar shower with me. There are a few things that rejuvinate the soul more than a refreshing hot shower (yes, we know what the other things are and we usally shower even after then).
The soal shower is inexpensive, works well with adequate sunshine, and extremely simple to replace. However, if you like a hot shower first thing in the morning...not an option based on no sun during the night. I have heard of people who heat water through whatever means, and then simply pour it in the solar shower. I am generally too lazy for all that effort. I have several aboard for the sumer so guests can "rinse" off after swimming.
This year I installed a wall mounted on demand unit. Since I have one in my house, I expected the unit to work well. The theory is simple. The unit rases the temperature of the water as it passes through coils (similar to a radiator). The problem with the unit is the issue we all deal with...water conservation. You run the water and adjust the faucets. The temp is now perfect. You use the shower head to stop the water, lather up, then open the shower head. The water coming out is cold until the flow rate, and demand, of the unit cycles on and heats the water. When I am home I turn on the shower, grab my girlfriend and shower (or whatever) as long as I like. The limited water tankage on the boat causes the water temperature problem. When I just turn on the boat shower...the water is perfect as I pump precious water over myself at the rate of 4.5 gallons a minute, Hell, in Iraq I lived on a gallon of water a day.
This past summer a member was kind enough to give me a cruise-air air conditioner (BEFORE you start cussing me, keep in mind he offered it on this site and you could have contacted him before I did. : )
I bought a Ryobi 2000 watt generator to power it ($ 599.00 at Home Depot). I plan on removing the on demand shower and giving it to a friend of mine who camps. I will replace it with an electric how water heater that I will run with my generator. Defender offers severl for less than $ 250.00. All of the models are rated at 1500 watts, or less.
I don't live in a whole in the ground anymore. Everything I own is not in a (far too heavy) rucksack.
I want all the creature comforts I can get.
