I posted this topic before, but now I have had a new thought. My boat was converted from CNG so the locker was not originally vented. Venting the locker for propane meant that the only possible solution put the vent under water whaebn on stbd tack. Otherwise it is fine. I don't like this arrangement. considering the situation, I began to compare this situation to the bilge of a boat with a gas engine. Ventilation is acheived by two vents. One at the bottom of the bilge and one to let air in at a higher point. Typically the inlet faces forward and the vent faces aft. Now, in my situation, at rest I have a proper vent. It is only on starboard tack that I do not. In theory, why would not the same type of system work for me on starboard tack?
