Stb'd Cockpit Seat Behind Helm
The LPG tank locker should drain to the outside, alright, and you're right on that count, but I can't speak to the details. Questions: Was the installation like that when you bought the boat? What did the survey say?Options: For the Hunter 35, I've been looking at a setup for quite a while on mine that would use the space under the seat on the starboard side that is behind the helm. It's open forward and the bottom is recessed a few inches. There are several options available that might accept a reasonably large tank in this place but it would require a hole the diameter of the tank and installation of a pan or box on the inside where the hole is cut. The lowest point would still have to be vented to the outside (easily done) but the whole thing would be outside the lazarette leaving that space available for inverter, water maker, etc.The seat is screwed in and caulked. The caulk and the screws are easily removed. If one put a piano hinge along the base of the seat near the walk-through the seat could swing on the hinge so the area under it would be wide open. This opens up another set of possibilities.On our boat this is an under-utilizied area that could be put to better use with a LPG tank. So far, though, the CNG has worked well. On our 77 day trip to Alaska and back we ran out and had to change tanks on the very last day. That's not bad. We did frequently use a hot plate when we were in port and had shore power available but that wasn't that often.
