Propane gas valve question
Feb 10, 2017
305
Hunter 41 Progreso
Does your propane valve get a little hot when turned on ?
Or is it mine going bad ?
Usually compressed gasses expanding through a valve make the valve cold not hot (PV=nRT) If the pressure drops the temperature also has to drop. Seems strange and worth investigating.
The solenoid is an electromagnet. There is a coil of wire that forms a magnetic field that pulls the valve open. That will generate heat as well as a magnetic field. When you are done cooking turn off the solenoid, it is draining your battery. :)
Likes: Valerio
