Has anyboby else with a Hunter 426, 44, 426DS or 44DS had a problem with the boat pulling to port as speed increases. If so what was the fix. If I cruise at 3000RPM and you let the helm go the boat will turn radidly to port. This is scary at speed. If not carful the wheel can be pulled from your hand. The boat also seems to take forever to respond to reverse thrust.Any help is appreciated.
