PROP upgrade size
Coyote
Sep 30, 2008
132
Hunter 30T Madeira Beach, Florida
Sooooo, as an additional add on to my last post -
Peter, at Marlowe - Hunter gave me the original 2 blade prop size of 15 x 12 RH, that is what the boat left the factory with,
FINE,, what should the new PITCH angle be for a 3 blade prop,,, yes, I know, less pitch,
and THANK YOU!!!!!!!!!!!!!!!!
DMo_17
May 26, 2020
2
Hunter 29.5 Bronte
On my Hunter 29.5 I also had one of the Martec 15x12 RH 2-blade props. I just had a Campbell Sailer 3-blade made up and the recommendations on it was 14x7. I will know in a couple weeks at launch if it was the right pitch.
Likes: sail sfbay
If you provided the motor, transmission and shaft details to WestbyNorth for them to produce your prop take confidence in the process. I worked with them, and got a prop that propels my boat exceedingly well. Improved performance under power and better sailing.
Likes: sail sfbay
