Folder's the Way to Go!
In answer to Mark Gale, my speed (according to the GPS, Loran, and Speedo) is 6.8 - 7.2 mph at 2900 - 3000 RPM (nearly flat out) on my Universal M25-EXP. From this, the top end for my Martec folder is as good (or better) than the three blade, but it does suffer when there is significant chop. To get the boat to handle in close quarters, you need to give it a bigger burst of power initially, but you can almost immediately back down as the prop bites into the water.I did notice that when backing out of my slip, there is less of a tendency of my stern to swing to port with the Martec than I had with the three bladed Michigan Wheel prop. From this, I observe that I can back up straighter now than I could before I replaced my original prop.By the way, the Alchemist and I sail out of Holland on Lake Michigan.
