Prop shaft size
4
Catalina 36mkII fox island
All, I am away from my boat right now and so I can't easily measure it, but I was hoping that someone could quickly tell me the diameter of the prop shaft on a 1998 Catalina 36 MkII Thanks in advance
Mar 31, 2004
244
Catalina 380 T Holland
No. It's likely to be 1"
as it is on the other boats that have the Universal M25XP, but you probably have the M35 engine on your boat. This larger engine MAY have a thicker prop shaft to handle the higher power of that engine (although the shaft on my C-320 with the Yanmar 3GM30 is still only 1"). You will need to wait for a more expert answer than either of us can give. Try to post this question on the C36 IA message board. There's a lot of C-36 gurus over there. Steve Alchemist C-320
