Prop Shaft Seal
2,422
Whitby 55 Kemah, Tx
packing gland
is what I believe you mean and if you do a search in the archives, you will see lots of information on the tips and tricks on how to do it.
Sep 4, 2006
5
- - Patrick AFB, FL
Packing Gland Material
Thanks for the words. I did a search of the forums. It seems like it's possible to accomplish. What is the packing gland material? Rob
Steve O.
short answer is yes
I did this on my 333 a couple of weeks ago. Very little seawater actually comes in. Most important thing is cut the new flax to size before you remove the old.
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
What size Gland Material????
My 1988 H285 has the (standard?) 1" diameter prop shaft. Any idea what size packing gland material should be used? (Just trying to save some time and not have to get down in there and measure..OK, call me lazy!)
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
My 1986 H28.5
with the OEM white nylon stuffing box uses 1/4 inch packing material. That said, it is best to measure the space between your shaft and the inside of the gland lock nut to be sure you have the right size depending on the type of gland you have. Packing materials are available at most boat stores and range from ordinary flax to the more expensive and long lasting teflon impregnated material. Since the Law of Unintended Consequences can and often does arise when you least expect it, I suggest that you NOT try to repack the gland with the boat in the water THE FIRST TIME. Do it on the hard first and gain the confidence and experience that all the parts will come apart as planned, and more importantly, go back to together as you would wish. I have never heard of a boat sinking while on the hard, but I know of at least one case where one nearly sank in its slip when the gland broke after being over-torqued by an owner repacking his gland....Lots of stuff in the archives on this.
L
Landsend
Give me a call I'll talk you through the procedure
I live up the coast ftom you. My number is 1-386-447-1838 Karl
