Prop shaft sabre 28
The folks who will know this are on the Sabre group. About a 1000 Sabre owners.
Sep 24, 2018
4,480
Catalina 30 MKIII Chicago
If you need a new shaft, you need to know more than just the diameter. If you have a local prop shop, its best to bring it in
"An old Sabre 28" is too vague to give you a confident answer. Check the Moyer Marine (Atomic 4 community). The Mk1 often had an Atomic 4 Gasoline engine. If so, a 7/8's prop shaft is often mentioned. The stickler is that you may not have the Mk1. A previous owner may have switched out the Atomic 4 for a newer diesel engine, as later models came equipped. The later diesel engines often used a 1" or a 25mm propshaft.
You would be safer buying an inexpensive caliper tool if you're trying to identify the diameter to replace a shaft zinc.
Here is an easy tool
If you are thinking about replacing the shaft, then there are more measurements needed than the shaft diameter.
how-to-measure-the-propeller-shaft-and-propeller-shaft-coupling
