Prop Shaft for 32' w/ Universal engine
Thyme1
Jul 14, 2010
7
Oday 32 Key Largo
Howdy Guys!... Must change my prop shaft. I know that it's 1" Diameter, but I'd like to know how long it is before pulling her out. 32 Ketch w/ Univerversal Diesel - Any Leads?
Thanks. Thyme
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I have a Westerbeke 30 but I'll measure mine this weekend for you and I'll measure from the end of the shaft to the inside of the shaft log on the outside of the boat and you can figure out the rest on the inside of the engine room
Feb 6, 1998
11,760
Short of pulling it and measuring the length physically the only other option is to call the builder and ask. Catalina for example keeps a "build sheet" for every hull they've made and they can tell you the exact length.
Unfortunately O'day is gone so I suspect you'll need to haul the boat & pull the shaft to measure it.
Thyme1
Jul 14, 2010
7
Oday 32 Key Largo
-Thanks, Rad! Much appreciated. What did you come up with?
trgadson@gmail.com
