Hey all,Any help and/or advice on any of the above is greatly apreciated. My mechanic has flaked out and I will need to replace the rudder, cutless bearing and prop shaft myself.Rudder: The boat is on stands now and I am assuming that I will have the yard lift the boat so I can insert the rudder shaft and then lower it back down until the plastic doughnut on the top of the rudder is in contact with the bushing glassed into the hull. The rudder shaft will not be drilled. Will I have to mark it in place then pull it out to drill it? I don't think there will be enough room to drill it out while it is in the quadrant. Should I grease the shaft? The boat is on asphalt.Cutless bearing: The original has been cut out. The original set screws have been drilled out. I'm assuming I will drill new holes and tap them for new set screws. Any suggestions on size and material? Stainless? Brass? Fill the old holes? Tap them for bigger set screws? I'm planning on a threaded rod, washers and bolts to pull the cutless bearing into the strut. Shaft: Once the cutless bearing is in I will push the shaft through the strut and into the shaft log. I have a new packing box and hose and I think I have that part covered. I will then attach the coupling to the shaft and the coupling to the transmission flange. I am going to buy some feeler gauges and do a preliminary alignment check. My slip is only about 100 yrds from the travel lift. Unless the alignment is way off I will let the boat rest in the water for a week before I do the final alignment. I've never done this before. Is this something for a do it yourselfer?Have I missed anything? Any tips, tricks, special tools, resources or advice? My yard is charging me $60/day storage and they charge $20/ft per lift for the travel lift. I don't want to pay the storage to wait for a mechanic and I don't want to have to pull the boat again...Arrrrrggggghhhhh!Thank you in advance,TimLake Tahoe1989 Hunter 30G
