prop shaft anode
Dec 18, 2016
41
Hunter 306 ft lauderdale
i have 2004 Hunter 306 with Yanmar. i am in west marine looking for new prop shaft anode. i measured the shaft inside the boat it mic'd at 1 inch. i assumed this OD would be same on water side prop. they do not have 1 inch anode. anyone recently change their's and remember the size please. thank you
Jan 5, 2017
2,502
Not a Hunter owner but the shaft dia. should be the same outside as inside until you get the the tapered part where your propeller is.
May 27, 2004
2,059
Mechanical and engine parts are often "Out of Stock" at West.
Now, if you want a Yeti cooler, a lovely stand up paddle board or
a beautiful flowered shirt they got you covered. :cool:
Likes: RoyS
Dec 14, 2003
1,450
I see you're in Lauderdale. Check Sailorman. Or check to see if by luck they have a 25mm. tight but close enough (25 mm = 0,984252 inch) You should be able to make it fit.
Feb 8, 2014
1,300
Columbia 36 Muskegon
Mechanical and engine parts are often "Out of Stock" as West.
Yep. They're always out of stock of everything. And you pay a premium price for it. They're my last resort supplier. Try Defender.com, Amazon, or eBay.
