prop shaft alignment
Oct 30, 2019
12
When I bought my boat it had a new (3hrs.) Yanmar. The entire drive line
was replaced from engine to prop.The manual recommends that I "adjust the
prop shaft alignment" at 50 hrs and then again every 600 hrs or one year. I
have had the boat for three years and other than filters and oil have not
done anything else. I figured *IF* the prop shaft was mis aligned I would
soon know it by vibration. There are no vibrations. In fact the drive line
runs really smoothly at all engine speeds. I figure if it ain't broke why
fix it? Or am I wrong? Is this a "must do"?
Yanmar 3GM30F w/331 hrs
thanks,|Garry|
Albin 82MS #17 "Half Moon"
@ Horseshoe Bay B.C.
Nov 8, 2001
1,818
Hi Garry
As you say "If it aint broke, don’t fix it" Sounds like it is OK to me.
I installed a Beta over six years ago and not checked treh alignment
since as there has hardly been any wear in the stern bearing. Sounds
good to me.....
Cheers
Steve Birch (Technical)
Oct 31, 2019
562
Hi Garry;
I agree with Steve- just take a good look at the stern
bearing, if there isn't any noticeable wear - more in one
direction than the other- then you should be okay.
Wilhelm, V-257
