I just finished rebuilding the combi and stuffing box. Let me say that getting the prop back
in was difficult. It came right out, but it took some work to re-seat. When the prop came
out, the forward pin unseated prior to the last lock ring dropping out. Since I didn't know
how many rings there should be, I assumed it was only the three that came out with the
prop. After about an hour of coaxing, I stuck my finger in the housing and something didn't
feel right. So, I eased out the 4th ring, then re-inserted the prop. Even then, with the
keyway lined up, it did not slide right in and it took quite a bit of turning to tighten the
forward lock nut.
Now that it is back together, can anyone tell me if I need to add grease to the prop boss? If
so, how? Do I need to remove something to add the grease?
Thanks,
JH
forward lock nut.
Thanks,
JH
