Profurl Roller Furling P-31 System
steve rainey
I have an older P-31 Profurl system and am in need of one of the Alum pole sections. Anyone have one they would sell? Also any of the 1/4" plastic bearings that go with this system if possible. The newer ones are thinner and don't fit as well.. Tks Steve Rainey
Jun 3, 2004
309
Prindle 18, beach catamaran Chicago (North Edgebrook), IL
Steve -- I have some foils, bushings and parts from an older Profurl unit. It was installed on a H-33 which I bought last year after the hurricanes. Tell me how I can tell if my parts are what you are looking for and maybe I can help. Henry
steve rainey
Hi Henry Your gonna be a life saver if you've got what I'm looking for. On the plastic (rubber) spool is stamped P31. I guess the best thing to do is for me to take a pic of the end of the foil and post it here. I have 1/4" rigging. Or if you've got a pic of the end of yours. I guess this is an older system. but its still in good shape otherwise...
steve rainey
Profurl
Henry The easiest way to do this is I've made an ink stamp from the end of one of my foils. If I had a fax # I'd send it so you can match it up with what you've got...Ok? my fax # is 912 573-2633 Steve
steve Rainey
Roller furling
Henry I have a pic of the end of the foil. do you have a fax # I can send it to? tks
