Steve
I have a 2003 Beneteau 331, with the roller furling main. The first year, pulling out the main and furling it was very easy and, for the most part, could be doen without assistance of a winch. This past year, however, has been quite a different story. Even with the winch, it is difficult to pull out.I have tried to research this issue and I have made sure that the boom is perpendicular, that the main sheet and boom vang are loose, that there is slight pressure on the outhaul when pulling the sail in by the reefing line, and making sure there are no creases in the sail as it is being furled. Interestingly, I did not have to pay attention to any of this during the first year, and it all worked very smoothly.Has anyone else experienced this problem or difficulty? Is there a problem with the outhaul car (and its bearing) not being able to handle the strain and needing replacing? The outhaul line does seem to have gotten somewhat stiff - should this be replaced (after just two years)? Is there anything else I should look for?Any help, suggestions and guidance would be greatly appreciated. As you may expect, this can be quite a frustrating problem.ThanksSteve
