Has anyone had a problem with the heat cycle on a 16,000 BTU Cruisair self contained unit? The the temperature never reaches the thermostat temp but the compressor runs for a while then shuts down while the fan still runs and 2 minutes later turns on again. It continues to recycle. I connected gauges while the unit was running and found that the high pressure reading went from 150 PSI to 410 PSI where the high pressure cutoff was engaged. It took about 2 minutes to cool down and the pressure reading went down to 150 PSI.I checked for blockage of air in both the input and output, dirty filters, etc. Everything was fine.BTW, the cool cycle works fine and doesn't shut off until the desired temp is reached.Does anyone have any ideas what's causing this?Thanks.Ken Catalina 42 MK I 2 Stateroom
