Problem using a hank-on jib with furler
Oct 19, 2019
921
Albin Vega 27 Limerick
I have a conventional furling genoa and also a #3 heavy cloth jib which
was originally a hank-on sail but which I converted to a furling jib
years ago for occasional use in strong winds.
I did this by replacing the piston-hanks by "slugs/sliders" that are
whipped to the eyelets on the sail where the piston-hanks were attached.
The slugs are slid inside the foil as the sail is raised.
The slugs were supplied by Plastimo, the manufacturer of the furling
system - for this purpose.
This has worked fine for years .. until now.
When I raised the full-size genoa after dropping the #3 jib last weekend
I couldn't fully raise the genoa, about 2 inches short of the top so
the sail is slack at the foot.
At least I had no problem furling the sail once(almost) fully raised.
I didn't have time to investigate & will do so this weekend.
The wind was only 25-30 knots apparent in gusts so unlike that the point
loading of the foil (slugs are about an inch long) did any damage to
the foil.
I'll try greasing a single slug with silicone grease and use the jib
halyard (with a downhaul) to see if it can run freely up the foil.
If it does, I'll try raising the big genoa again.
If not, I'll go up the mast... :(
I'm hoping that there is something (a cable tie???) stuck in the groove
- I suppose that the worst case is damage to the foil but as I said
above the winds were not that strong.....
Is it OK to use silicone grease?
What have I forgotten?
Any comments welcome.
Thanks,
John
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Jan 28, 2001
694
#ygrps-yiv-1064235980 P {margin-top:0;margin-bottom:0;}
Search for sail slide lubricants and read the review by Practical Sailor. You might a bit of insight from it. Walt
From: AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of John Kinsella John.Kinsella@... [AlbinVega] AlbinVega@yahoogroups.com
Sent: Tuesday, September 11, 2018 3:54 AM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Problem using a hank-on jib with furler
This message is eligible for Automatic Cleanup! (AlbinVega@yahoogroups.com)
Add cleanup rule |
More info
the foil.
Thanks,
John
May 30, 2006
1,075
There's a dry lube spray for that purpose. I think sailcoat? Is the most popular?Look it up. Put on your main slugs too.groundhog"John Kinsella John.Kinsella@... [AlbinVega]" AlbinVega@yahoogroups.com wrote:
the foil.
Thanks,
John
Oct 19, 2019
921
Thanks.Maybe using silicone grease was the problem?It may have actually increased the friction of the big Genoa "bolt rope" (actually a strip) in the slot in the foil?I suppose I'll find out at the weekend?
John V1447 Breakaway
Sent from
TypeApp
Jan 28, 2001
694
#ygrps-yiv-1310896110 P {margin-top:0;margin-bottom:0;}
John, do a search for sail slide lubricants. An article from Practical Sailor will come up which you will probably find helpful. Walt
Add cleanup rule |
More info
the foil.
Thanks,
John
May 30, 2006
1,075
Think the theory goes that wet lube is slippery at first, but attracts dirt to stick.Of course you have to reapply any of the lubes. They wear off."John.Kinsella John.Kinsella@... [AlbinVega]" AlbinVega@yahoogroups.com wrote:
Sent from
TypeApp
Oct 30, 2019
1,459
Please remove me from the list.
Nico WalshNicholas H. Walsh P.A.Admiralty and Maritime Law; Probate Litigation; Commercial LawPhone: (207) 772-2191Fax: (207 774-3940P.O. Box 7206120 Exchange St.Portland ME 04112This message is from a law firm, and may contain information that is privileged and confidential. If you suspect you are not the intended recipient, please delete the email and call us.
Oct 19, 2019
921
Was just talking to my sailmaker - apparently a lot of people
have the same problem "It Seemed Like a Good Idea at the Time".
He advises using detergent (wash-up liquid) to clear the grease from
the track...
Thanks,
John
On 13/09/18 00:33, groundhogyh
groundhogyh@... [AlbinVega] wrote:
Jul 2, 2016
28
Sailkote for the slides / slugs, and McLube / Harken One Drop Ball Bearing Condintioner for the roller furler. Works great. Go to Harken's website, has great info. On Thursday, September 13, 2018 5:03 AM, "John Kinsella John.Kinsella@... [AlbinVega]" AlbinVega@yahoogroups.com wrote:
the track...
Thanks,
John
Oct 19, 2019
921
Thanks to all who replied for the excellent advice.
I used ordinary detergent (wash-up liquid) in large amounts and
ran a sail slide up and down the slot many many times to remove
the grease. Also washed the bolt-rope/beading on the sail with
copious amounts of detergent.
The sail now slides up and down the slot very smoothly.
A lesson learned..
I'll buy some dry lube and apply it also..
On 13/09/18 11:33, Jim Sexton
sexton1313@... [AlbinVega] wrote:
