Steve Jaffe
Even though I leave the charger on at the dock for several days and my test button says there's a full charge on the batteries, I have intermittant problems getting the engine to start. Yet, after it DOES start and I have used it a bit (half hour or less) it has no problem starting on ONE battery!Could this be a starter button problem or a starter motor or solenoid problem.( or ALL of the above) Also, I am able to physically swivel the starter button 15 or 20 degrees.( I tried it thinking the button might have a short) Is this normal? Has anyone had similar difficulty? I thought I'd seek advice before ordering a new starter button from Ward at Beneteau. The boat is a '99 and the problem has only recently arisin.Steve Jaffe (also sljaphe@aol.com)
