ralph champagne
While on a port tack, close hauled, with boat heeledabout 40/45 degrees, with 20 kt winds; I had to cutthe wheel full to starboard to maintain forwardcontrol. Then apparently the rudder must have comeout of the water ! , because the boat just turnedup wind and I had no control with the steering ! Is this a common problem with the 331 ; Should I find a boat with a deep keel / rudder , instead ofa bulb keel and short rudder. Once the boat flattened out I had control again, butonly to find out the same problem again when pointing. I guess the boat can't take this type of sailing.
