We have a ProFurl LCI32, admittedly a much earlier model. When I did my research, I had the same choices. I chose the ProFurl for few reasons: didn't need a halyard restrainer because of Profurl's unique what-I-call "Darth Vader" top halyard swivel arrangement, , didn't need maintenance, had the long link plates option to get the tack of the sail off the deck, and could use my existing forestay (although I did redo the standing rigging at the time I had the ProFurl installed). Almost 10 years later I'm still a very happy skipper. Never had any problems with the equipment. ProFurl, as far as I know, is the ONLY furler manufacturer that allows using a winch on their gear, although I never have felt the need to do so. Their foil is very good and has a great feeder system.
When you do the $$ comparison, don't forget the cost of the halyard restrainer, 'cuz if you don't install one, you'll wish you did, right after you get your first halyard wrap and mess up your forestay.
Happy shopping!
PS Whatever you do, yes, check your jib's (or jibs') luff length first.
