Priming Fuel System on a W20B
Sep 15, 2013
708
Catalina 270 Baltimore
Fellow Sailors. I have a Westerbeke W20B on a Cat 270. I am getting ready to check and replace the fuel filters on the engine and water separator. To prime the system after replacing the filters the service manual says to turn on the ignition switch for about 1 minute and allow the electric fuel pump to prime the system. Nothing else. Is that all there is I need to do? Am I missing something? Also any additional wisdom on the subject will be greatly appreciated. Thanks...Steve
Apr 11, 2005
57
Bayfield 36 Rock Creek
Yes, plus open the bleed screw on top of the spin on fuel filter until all the bubbles are gone. When replacing filters be sure to fill completely with fresh fuel, rock from side to side to release air bubbles before installing. Pretty easy, all in all. Let engine run to make sure you don't have air in lines.
Good luck!
Tod
Feb 6, 1998
11,723
Yep with the Mitsubishi based Westerbekes just turn the key and wait for the clicking of the pump to slow. Neat, clean and as easy to bleed as it gets...
Sep 15, 2013
708
Thank you very much for your swift and competent responses. I will be tackling this with much less anxiety now. Thanks again...Steve
