To Cure or Not to Cure
In order for rust (corrosion cells) to form, 2 things are needed. One is Oxygen, which it gets from exposure to air and the other is an electrolyte (sea water) for electrons to flow from one place to another. Basically, a corrosion cell acts like a battery. If you cut off the air supply by covering it with paint, epoxy or whatever, and cut off the flow of electrons by keeping the surface clean and dry, you have stopped the rust completely.So, Capn Ron and Daryl are both correct. If you treat it like Capn Ron says , you should be OK. However, if you are looking for a miracle cure and do a half ass job of surface preparation and coating, then daryl is correct.The bottom line is, if you cant take the time to to it properly, you are wasting your time.
