Firest, I'd like to thank those who have posted advice on this forum about the changeout process. GREAT and usefull information!
I had noticed a mild stumble recently and decided it was time I changed the filters. Our 280 engine systems are lightly used even though we take her out 20+ times a year so I haven't changed the filters in 4 years and things were fine until recently. I had started to see an increasing amount of weeping at the lift pump too so I changed that as well. Here is how it went.
First of all, the racor 110A primary is in a tough spot to work on - low in the "tunnel" just above a wiring bundle. Tried to unscrew the bowl with wrenches (box and strap) to no avail. It even started to pull the screws out of the fiberglass. Well, I bit the bullet and removed the whole assembly (as some suggested I might have to do), put the mounting flange in a vice and cranked hard on the nut at the bottom of the bowl. It finally broke loose. The fuel in the bowl was almost black; full of tiny particles but no snotty sludge and maybe a cc of water. Next, I replaced the lift pump and then pulled the secondary filter (which looked pretty clean). I reconnected the head of the Racor to the lines, prefilled the bowl, screwed it back onto the head and remounted the whole assembly and opened the fuel valve at the tank. Next, with the engine filter/bowl still disassembled, I pumped the lift pump until some fuel came out of the top of the secondary housing. Then, I remounted the secondary filter, filled the bowl and screwed in back on. Opened the bleed screw at the top and pumped some more. I was surprised that it only took about 6-8 pumps before it started to bubble out and was clear with just a couple of more pumps. Feeling cautiously optimistic, I disengaged the fuel shutoff and asked the admiral to hit the starter. Well she fired right up, stumbled just a tiny bit then ran smoothly!
HOORAY!!
After cleaning up we decided to take her for a test run and was very pleased with the restart and smooth operation. It did NOT fix another symptom I have but I'll put that in another thread.
Thanks again to all who have advised me on this chore.
Clark
HOORAY!!
Clark
