preventing galvanic reaction between SS fasteners and aluminum hardware
63
Hunter 34 Bayou Chico - Pensacola
We're doing a total top-to-bottom paint job on our Hunter 34 and have removed a lot of aluminum hardware that was fastened with SS bolts and screws. Almost all of them had that white powder associated with galvanic reactions. When we get ready to reassemble everything what can we put on those fasteners to prevent the reaction with the aluminum? Most of the problem areas are on winches, and other aluminum that is anodized or bare and painting the items isn't very practical.
Jun 25, 2006
63
Jun 1, 2005
772
Pearson 303 Robinhood, ME
good question
I'll be watching the posts. I have an aluminum painted spar. The P.O. attached a stainless bracket to hold the steaming light. I was going to replaced the light and noticed corrosion. I sanded the area... masked off the rest of spar... and applied a self etching aluminum primer. Then being anal retentive that I am... I cut a piece of rubber membrain to seperate to two dissimilar metals before I attached the bracket. In hindsight... I should have fabricated an aluminum bracket and used aluminum screws. That is the "French" in me... by the time I realized I have done something stupid... it is usually too late!
Jun 1, 2005
772
good question
C
Carl
Tef-Gel
Our preferred method in the yard is Tef-Gel, but there are other products that do the same job. Carl
C
Carl
Tef-Gel
7,513
Alden 50 Sarasota, Florida
choices
you really should use TefGel, Lanocote or some other anti-galvanic corrosion gel on the fasteners to help prevent the mast and fasteners from reacting to each other.
7,513
choices
Tim R.
May 27, 2004
3,626
How about blue locktite?
Prevents corrosion and keeps things together. Tim R.
Tim R.
May 27, 2004
3,626
Ross
Jun 15, 2004
14,693
A rigger I know just applies vinyl electrical tape
to the fixture to isolate it from the aluminum. I would apply teflon paste pipe dope to the bolts to keep water infiltration to a minimum.
Ross
Jun 15, 2004
14,693
Joe
Jun 1, 2004
8,233
a combination of both...
Apply a layer of plastic electrical tape on the large areas such as bracket bases. Use one of the anti galvanic/corrosion products, mentioned by carl and don, for the fasteners. You can pick that stuff up at any chandlery.
Joe
Jun 1, 2004
8,233
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Good old fashion
Lanacote, non toxic, easy to use and proven effective over many years. Available here: http://shop.sailboatowners.com/detail.htm?fno=400&group=1147 Dave Groshong Customer Service SailboatOwners.com Toll Free 877-932-7245 ext.116, Mon-Fri, 9-5 Pacific
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Good old fashion
Jun 25, 2006
63
Considerable difference in cost
2 oz of tef-gel for $24 or 4 oz of Lanocote for $8. Can anyone defend spending 6 times the cost of Lanocote to use the tef-gel option? I've never used either but will certainly use one of them when we start reassembly. Any testimonys on where else these products can be used other than fasteners?
Jun 25, 2006
63
Jun 5, 2004
29
- - Alameda
Pipe Thread Compound
This has worked great for me for many years. It comes in a little tube that you knead. Apply it to the threads and it sets like chewing gum. Keeps water out and prevents corrosion. I used it on all my mast fittings 11 years ago when we had it painted. The telltale sign is the paint blistering up next to the fastener. Not happening yet. I bought it at the hardware store. Anytime I had to remove a fastener, it comes right out. Allan
Jun 5, 2004
29
- - Alameda
