Pressurizing an Alcohol tank
10
- - Cincinnati, Ohio
My O'Day 30 has an alcohol stove with oven. In the hanging locker is the alcohol tank which has a valve similar to a valve on a tire. Does anyone know if that is supposed to be pumped up with a hand pump? If so, to what pressure, or is a cylinder supposed to be attached? The previous owner never used it so he has no information to offer. Also, is anyone familiar with the procedure for lighting the Hillerange stove and oven? My old boat had a Kenyon stove that is not at all similar. Thanks for any and all help. Mike B
Jun 3, 2004
109
Oday 40 New Bern
O30 with alcohol stove and oven
That fitting is exactly what you think it is and a hand pump can be used to pressurize the tank. I would have to go and look at my (avail) O28 to see the max pressure, but I have gone with the inflator on a battery eliminator because it is so awkward to hand pump the thing. As far as procedure, start with everything off/shut, pressurize the tank to about 15 psig, open the tank isolation valve, crack the valve to the burner you are going to use until a TINY bit of alcohol comes through to the bottom of the burner. You don't even really want to see it. Shut the burner valve. Light the alcohol and let it burn out. Then crack open the burner valve, light the burner and adjust the heat. The initial lighting preheats the tube that volatizes the alcohol into a gas. When you are all done, secure the burner, then the tank, then depressurize the tank. It takes a few tries to get the procedure down, but once you have it, there isn't a lot to it. Just don't get heavy-handed with the initial shot, or you will be replacing the curtains over the stove. Hope this helps. Bill Coxe, O28 (avail)/O40, New London, CT
