Pressure Washer
1
- - Lake Norman NC
Good Morning, I'm considering using a pressure washer on my boat.*! First is this a good idea and secondly if it is what size pressure washer would you recommend using?
C
Chris Burti
Yes, with care.
They work well aboard on hard surfaces such as hull and rigging. They are great for washing the dirt out dirty dock lines, sheets and halyards. It will remove a lot of the oxidation from faded gelcoat and vinyls. 1200-1400 psi is plenty big enough and yet small enough to minimize risk of damage...lighter too. Keep away from wood and fabric as even the lower pressures can do considerable damage.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
They will blow out the caulk/sealant in seems, around windows, fittings, etc if not careful.
Catalina 320 Dana Point
If there are chips in the gelcoat a pressure
washer can make them very much worse if used improperly.
