Car Wash Blues
Jeff,To me, this is a 'maybe'. Some of these units can apply enough pressure to cut into gel coats. Type of tip used, distance from surface, length of time on surface, etc. should be watched carefully. With that said, proper use should not be a problem. Careful around caulked joints or softer materials.There are also soaps to add to pressure washers that may be helpful. Jan
