The coolant pressure cap gasket is broken on my H33.5. I noticed that the Yanmar replacement is fairly expensive and difficult to obtain at this time. Is there a known generic replacement? the cap has a number stamped on it "0.9"
Most Pressure Caps keep the pressure between 14 to 18 PSI to prevent boiling losses. The coolant used by Yanmars is no different than those used in automobiles as they relate to their boiling points. Take the cap to a NAPA or reputable Automotive parts dealer and see if a parts specialist can match a substitute. Yanmar does not manufacture Pressure Caps so they use available production standard sizes. I have used substitutes in the past with no issues. With supply lines being disturbed getting certain parts may be difficult hence the need to use substitutes.
At a guess that .9 is either bar or Kg/square centimeter which translates to about 13 PSI which will be the relief pressure of the cap. You don't want any replacement to be too different from that, if it is the correct original.
I've tried a couple different caps and they leaked, that upper gasket that is cracked in your picture is larger in the Yanmar caps. The aftermarket caps have a smaller diameter and so when engine shut off it leaked out top of Hx exchanger instead of going into overflow tank. Effectively made it like the overflow wasn't there.
These seem to be hard to get these days. A local (tractor) Yanmar dealer wanted almost $100 CDN for the part including shipping and customs. I have ordered one with shipping to a USA address $30USD. Hopefully I can get it in time.
Thank you all for your responses.
