Prepping iron keel
Aug 14, 2011
182
Hunter 35.5 Legend PCYC Shediac, NB
This past season has cause some water to penetrate the surface of the iron keel on my boat. The rusted iron is on the lower portion of the keel but there are 4 or 5 spots about 6". I dont have any pictures but will take some tomorrow.
I know that i have to grind these ares down to the bare iron but how do i make a seal and prevent it from coming back is my concern.
Any input would be great
Thanks
Feb 20, 2011
8,062
Thanks
As soon as you've ground down the spots to bare iron, apply a rust converter-type paint.
You really can't stop the rust from returning, just as you can't stop entropy. You can, however, fight it. ;)
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Get it down to bare metal then apply two coats of epoxy. Before the epoxy is fully cured apply a couple coats of barrier coat to act as a primer for bottom paint. Before the barrier coat is fully cured apply the first coat of bottom paint.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I would pass on the epoxy and after getting down to bare metal unless you have some huge craters to fill. Go to multiple coats of Interprotect 2000 as per directions followed by bottom paint while the last coat of Interprotect is tacky to,the touch. The Interprotect is essentially a 2 part epoxy anyway.
Another choice if you are just dealing with a small area is to use several coats of Primocon over the clean bare metal before applying bottom paint.
-na -NA Anywhere USA
I use to work on boats for many years as a dealer. With cast iron, wire brush the metal to get a clean shiny surface. Wipe off with acetone or alcohol. Then apply a metal primer but make sure it has or is ZINC CHROMATE to prevent the rust from reoccurring. then apply a two part epoxy filler. I use to use WATER TIGHT although expensive and a slower cure but it sure held fast and water could not penetrate it. Sand smooth and then I applied barrier coats over it to seal it.
The epoxy putty sticks did not work that well.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
I did mine the summer before last. I had the old coatings, fairing, etc removed down to the bare metal with a needle gun---long job. Then I wire brushed with an angle grinder and a coarse twisted "bristle" type wheel. I immediately coated with a rust converting coating, then a coat of IP2000. Let dry, faired with epoxy and filler, then 4 more coats of IP2000. When I hauled out last year- after 2 months in the water there were 3 or 4 tiny spots that were ozzing rust. Let dry over winter, dremeled the little spots and filled with fairing compound. Last fall at haul out there were 3 little spots- different places, filled them with fairing compound yesterday. Anti fouling today.
Gunni
Mar 16, 2010
5,937
I have had great success on these small rust spots by simply chipping off any rust, wire brush to shiny metal, then mix and paint with marine epoxy, use a wire brush to scrub it deep into the repair. When set, I rough the surface (120grit sandpaper) and paint with bottom paint.
Aug 14, 2011
182
Thanks for the update. I do have some Interprotect 2000 left and will do that approach again. That is what I have done in the past and it held ok but wondering if there was something more permanent.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I'm not sure it's possible to completely "dry out" an iron keel and keep it from weeping and rusting in spots. I just plan on spending an hour or so each spring sanding the rust spots, applying a few coats of Interlux Primocon and then bottom painting. No big deal.
FYI, I was surprised to see that you have a Pearson 28-2 with an iron keel. Friend of mine has a 1986 Pearson 28-2 with a lead keel. Different models?
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Clean the cast iron as well as you can, be it sand blasting, needle gun, or grinding and wire wheels. You can also pound rust scale off with a ball peen hammer. Coat with phosphoric acid immediately to create a layer of non-rusting iron phosphate. Coat with at least 2-3 layers of coal tar epoxy (which is used on barges, buoys and the like.) Fair with a below waterline specific fairing compound. Sand, fair, sand until you are satisfied or sick of it. If you burn through the CTE while sanding, re-do the phosphoric acid and CTE in that spot. More coats of CTE over top of the fairing compound. Bottom paint.
Mar 1, 2012
2,182
Exactly
Aug 14, 2011
182
The Iron keel is on my Hunter 25.5 that is for sale :) My new to me Pearson has a lead Keel.
There used to be a forum dedicated to the 28-2 but doesn't appear to be active. Does your friend have any good sources to share. I would love to see some pics and mods that have been done
