Preparing to Purchase - '84 Hunter 31
Mar 28, 2014
51
Hunter 31 Lake Norman, NC
I am just before buying an '84 Hunter 31. This will be my fourth boat (2 power boats and 1 sail boat previously) and my entry into the mid-size, inboard, cruiser. I am not a novice boater but would like you insight with regards to the particular model of boat. From members' experience, what advice can you give? . . . regarding Yanmar Diesel? . . . regarding typical maintenance issues? . . . regarding handling and docking? . . . what experience has taught you? . . . regarding unexpected issues and opportunities? . . . anything else that you can share. Thanks in advance . . . Fair winds! Chuck.
cjfj
Oct 16, 2010
83
hunter H34 Mayo, MD
Do not let the engine run out of fuel or suck air. This can be a bad thing. It' is not self bleeding as a gas engine is.
They handle like a dream and are great boats for all around crusing, imho.
Nov 6, 2006
10,256
congratulations ! There are a couple of things that should be closely inspected. The mast compression post and the mast support beam is very much like the one on the H-34 .. if you search this forum for "Mast support beam" and "Mast compression post " you'll find several posts.. Another one to look at carefully are the chain plate tie rod anchor points. There is a big stainless tie rod that anchors into a steel angle iron which is buried in the structure inside the cubbies, A chronic water leak in the shroud attachment plate bedding on deck can rust the angle iron enough that the tie rod will fail. Search this forum (and the H-34 stuff specifically) with "tie rod" or "shroud anchor" and you'll find some info. The Yanmar is a little jewel if properly cared for. Given clean fuel and clean oil, it will run a long time. Check that the valve clearance is correct and that the head bolt torque is OK. Check the air cleaner .. they tend to disintegrate..leaving a thin peforated metal cone... replace with an open cell foam meant for air cleaner use. The starter circuit can get iffy due to dirty connections in the connectors between the engine and instrument panel. Check the exhaust elbow for blockage .. If the boat has been on the fresh water lake most of its life, that is probably not a problem.. The 31's are fine boats.. fun to sail and have comfortable space inside.
Mar 28, 2014
51
Thank you for these valuable insights! I will definitely keep these in mind as I make my inspections of the boat. And, my inspections may uncover other areas for "discussion" on this site. It is great to have this forum and I appreciate the resource it offers. I will dig a bit deeper into the references made. Thanks all! Chuck!
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
We have had a 1983 Hunter 31 for about two years now and it has been a lot of fun and a very nice sailing boat. We sail with 155 Genoa and she sails pretty fast, we raced this October in a 150 mile offshore race and we came in second in our division. I agree with previous post our Yanmar has been steady and reliable, change the oil and filters' fuel and oil.Also, the air filter will disintegrate as mentioned above. I would check the mixing elbow inside and out they can corrode quickly, especially in saltwater not an expensive fix though. It might be worth looking at the steering linkage the quadrant and the cable (you will have to remove a panel). The dogs on the ports tend to be a little fragile so don't tighten them too much. We also had some leaky ports and hatches, we replaced all of the gaskets and she is dry as a bone. We also had an issue with the bolts linking the shaft to the transmission vibrating loose until we treated the threads with loctite. PM me if you have any other questions. Congratulations we have had a lot of fun with ours.
May 24, 2004
7,235
CC 30 South Florida
Regarding the diesel engine, they are sturdy little fellows. 90% of their problems when running rough or wont start are fuel system related. Diesel fuel if allowed to sit for long periods and if untreated can be a breeding grounds for bacteria which in turn can clog your filters and build up sediment at the bottom of the tank. You should have a filter/water separator which is called the primary filter and then an engine mounted filter known as the secondary filter. When you replace filters you may need to bleed air from the fuel lines (Google procedures). Some engines are raw water cooled and others have a heat exchanger and use automotive type coolant. The difference is the liquid that flows inside the engine passages but both draw and exhaust raw water for cooling. That means periodically replacing the impeller and keeping the mixing elbow clean. The oil in a diesel usually turns instantly to black but that is normal, it is hard to suck out all the old oil and slightly worn engines have combustion by-products contamination. Dirty oil is not a problem that is why the oil filters are there for. Heat is worst enemy of oil as it degrades the viscosity. By the way do not use anything thinner than 20W40. The pull cable to shut the engine off activates a fuel cut off valve. At the control panel you will likely have a Tachometer, a key switch (diesels do not have ignition) a starter push button and warning lamps and a buzzer for 1) low oil pressure, 2) overheating and 3) not charging. There will also be a toggle switch to test the overheating lamp and the shutoff cable. It is normal to have some slight engine vibration at different RPM points but if excessive suspect the motor mounts which can look good and be shot but also check engine alignment and propeller shaft. Yanmar has a strict dealers agreement which means only the authorized dealer in your area can sell you parts. Go their web site and find out who the dealer in your area is. Pricing is controlled and availability is quite acceptable. Try to get a shop manual for your model engine if you plan on doing your own repairs. When the engine smokes it is ndicative of its condition; White smoke is water vapor or overheating, bluish smoke is burning oil, black smoke is overfueling and can point to a clogged mixing elbow or fouled propeller. The engines do not like to idle at low RPM so keep them around 900. Diesels operate at high compression and can get quite hot so before shutting the engine off let it idle and cool off for about 5 minutes. Hope these short list of hints can be helpful.
