Pre strainers
Rob
Hello peggie,, its been a while since Ive been on and since spring is just around the corner the projects are piling up....(not that I havent been doing them all winter also) One project that ive been debating about for some time is adding a pre strainer on the intake side of our head.....The strainer I am thinking of was used for our fresh water pump ...it worked quite well...when I replaced the pump last year the new unit came with a new strainer so now I have an extra. The strainer is a Raritan with 1 1/2" fittings. it has a spin off clear bowl so you can see the debri and clean and rinse when needed. The main reason I am thinking of doing so is that ...because of the alge blooms in the sassafrass and around the bay we seam to have a nasty habit of picking up all types of particals in our intake.....these then migrate to the head unit and lodge in the bowl rim......where they have the nasty Habbit of ...Rotting......and the SMELL!......Ive cleaned many times, used treatments and rinses only for the problem to come back again and again......So I wanted to nip it at the source...the intake. I would like your comments on this and possibly the down sides......besides having to empty and rinse the strainer bowl. Thanks Rob Leviosa
