Another reason to get a survey
especially if you are new to sailing is the sea trial portion of the survey. Remember, there are two key components to a full survey: the inspection, and the sea trial. I agree that your warranty might make the inspection portion worth less, but you might find it useful for an experienced professional to put the boat through its sailing paces for you. He may be able to show you things about the boat's performance that you wouldn't be able to figure out yourself (i.e., how difficult it is to reef the sails, how the boat reacts with a strong wind beam on). A good surveyor will also know better than you how a boat should perform, and can help you determine how this boat matches up with your skill level and sailing goals. If you are spending the money to buy a new boat, it is worth a few hundred more dollars to know that you are not only getting a sound craft, but one that is right for you.
