For the past few weeks I've been working on replacing the teak trim on my boat that covers the hull-to-deck joint at the stern. I thought the hard part would be fabricating the curved pieces (bent in 2 dimensions). As it turned out, fabrication was a piece of cake.
Last week I tried mounting them. It was a disaster. I broke screw after screw trying to drive them into the deck. When I went to the next size bit in my index the screws would strip. I finally gave up and and spent last night epoxying in bungs in my trim piece in the holes that now have a broken drill bit or screw underneath them.
What do ya'll recommend for a drill bit size for #12 ss self tappers? Is there a lubcricant I should use on the screws when I try to drive them? If so, will the lubricant interfere with the boatlife caulk I am using to bed the teak to the glass?
This has been a humbling experience.
