Powering A/C at anchor
277
Hunter 22 Fin Keel Lake Martin
I've got a 5000 btu window A/C unit installed in my cabin into the lazerette. I'm thinking a 800/900 watt portable generator will power it. Has anybody tried something along these lines?
I just picked up a generator and am looking for ways to mount it maybe on the transom to power the boats A/C when we are at anchor and trying to sleep on these hot nights.
Thoughts and Idea's?
Jun 28, 2005
440
Hunter H33 2004 Mumford Cove,CT & Block Island
A 5000w unit draws an average of 5.1 and 5.5 amps when running more on start up. Start up load will be the issue with generators.
Spend the money and go with a Honda 1000 or even 2000, quieter than the competition, and can handle the surge with their inverter technology. As a bonus it will come in handy at home for those electrical outages that seem to happen more and more these days. I am happy with our H2000.
Beneteau 46 Georgetown YB
This weekend I will complete installation of a Yamaha EF3000iSEB in the transom locker. I have designed an aluminum rack and frame with a slide out aluminum tray into which the unit sits. The 3000 comes with a 3o amp outlet and powers one of my 18,000 btu reverse cycle units. It can't handle both. 53 db makes it as quiet as the Honda, but it is 5" narrower that the Honda 2000.
KD3PC
1,069
boatless rainbow Callao, VA
spend a few dollars on a CO alarm/detector as sleeping whilst these run, unattended can be fatal
Or two
On a nearby kentucky lake just a few weeks ago, two folks were killed while asleep and the gennie running....CO poisoning.
Transom may not be the best place to have it, as the surface wind will carry fumes up and over the boat.
YMMV
Feb 6, 1998
11,772
Or two
YMMV
+100!!
There have been a number of CO poisonings due to the use of portable generators..
Jun 28, 2005
440
I'm Confused;
The Honda EU2000i is 11" wide actually (20.1 x 11.4 x 16.7)
The Yamaha EF3000iSE/B is (26.8 x 17.5 x 21.9)
With electric start, higher capacity, and Boost technology, the Yamaha is better suited to your application, it is also significantly heavier. It is however not smaller in any dimension.
If you had a wet exhaust, you could compare it to a Panda.
Jun 14, 2011
277
I've already got 2 CO alarms installed. Believe me I'm no fool I like my life... mostly. :D
May 24, 2004
7,228
CC 30 South Florida
Even though a 700W generator may run a 5K compressor unit, in instances it may not be able to provide the start up power required. It may also have to operate at maximum RPM to produce the required power thus increasing fuel consumption and shortening running time per fuel tank capacity. Getting up every 3 hours to refuel a generator is not fun. Cut yourself a rubber pad in which to seat the generator, it will collect oil and spilled fuel plus avoid the black marks the rubber legs may leave on your gelcoat. I like to place a generator where the wind coming from the bow as the boat swings at anchor will blow the exhaust fumes away. Tie it up with a safety line to avoid dropping it overboard and run a short heavy gauge extension cord adapter to the boat's shore power inlet. Keep the gas can away in a place where any fumes can flow overboard. Place a pan under the A/C unit to collect condensation and open the lazaratte to improve compressor cooling. Another consideration for the generator is weather. Find out how your will fare under rain and if possible devise some kind of canvas protection. Some of the units have cowlings that will allow them to run under a storm but others just quit. Go enjoy that cold A/C.
Jun 14, 2011
277
Good thoughts. above.
The Lazaratte will be open during operation of course. I plan to hang the generator out over the water on brackets I'm fabbing up with thick rubber isolators to kill the noise and vibrations.
As for fuel I'm going to find a way to tie it into an outboard tank with hose. That will give me 6 times the fuel capacity.
Keep the good thoughts coming!
Jun 6, 2006
6,990
I'm almost afraid to ask but does a 23' sail boat typically have a head and galley? Kinda scratching my head as to why you would want to consume the very limited space with an AC and Genset.
Quite frankly I'd be investing in some sunscreens for the forward deck and 12 volt fans but then I like it hotter than most.
Or two
YMMV
That was/is a concern with the air cooled generator. I already have one CO alarm, putting in another two so I will have a CO detector in each cabin. The plan is to run the A/C before bed to cool the cabin down. Then shut down the generator & go to bed.
And I was confused - I actually meant the Honda 3000 (with the 30 amp plug), and it is only an inch wider than the Yamaha. But it has been a busy summer at work and I compared the sizes way back in June.
Oct 17, 2011
2,809
Ericson 29 Southport..
I'm curious, and not to be contentious one iota, but with onboard generators why not pipe the exhaust overboard? What with fuel tank vents, black tank vents, engine exhausts, air conditioner water out, bilge pump drain, cockpit drains, ALL piped outdoors, surely this cannot be terribly difficult.
Can it?
Jun 14, 2011
277
Hehe yes my 23 does have a head and galley. Although I usually grill on a small propane grill rather than cook inside.
KD3PC
1,069
Can it?
Although the gennie in the OP is "onboard", it is a portable and will not be running below decks. Some sailors have installed portable gennies as permanent and have done exactly what you suggested...pipe the exhaust out a convenient lazzarette and added a fuel can to extend the run time.
The rub comes in while running that setup, as it has not been "marinized" and is usually "air cooled" and they open the hatch or a door or somesuch. Chafe and heat can work against common safety windows.
The big item for me is CO poisoning....even venting the exhaust "away" does not guarantee that the bad stuff is not going to blow back on you or what happens when the wind changes. CO is odorless, tasteless, quick and while one sleeps it can kill. Many are killed on lakes, where the wind is not enough to move it away from the boat, and they are just hanging out around the boat.
YMMV
Mar 26, 2011
4,041
Corsair F-24 MK I Deale, MD
There is also the matter of exhaust temperature. Without water mixed in, it will be extremely hot and melt any rubber or plastic. A whole different set of problems.
Jun 14, 2011
277
That is why my proposed setup will be like the engine. Outboard of the boat entirely to help keep fumes away from us.
Mar 28, 2007
637
Oday 23 Anna Maria Isl.
it would be cool if an outboard engine maker would design a model with a generator head that could be clamped on top of the engine cowling.
It could be small, easily stored and brought out while at anchor.
could just have a pass through power take off on top of cowling.
Would be water cooled and run quiet.
Jun 28, 2005
440
Our Honda 2hp outboard is aircooled but its exhaust is underwater and is quiet, watercooled is definately quieter, that is a great idea for a marine generator!
Honda has the technology, they just have to mix and match.
Jun 14, 2011
277
Cool idea. But they'd have to do something to control the throttle of the engine with the load on the gen head. Probably more complicated than worth the trouble.
